Results 1 to 10 of 17
Thread: Idle at 2000rpm
    Mar 2013
    Tweed Heads NSW
    Idle at 2000rpm
    Hi guys. Got a tricky one. Since I live 1.5hrs from the nearest wallet drainer, I thought I'd run it past you. The beast has been running like a dream for the last 20,000k's, but I started it up the other week and it went to 1200rpm on startup at idle. Over the next week or so it went up to 2000rpm. This was the only symptom that something was wrong. I have searched high and low for an answer and they all seem to correspond with other symptoms that my car does not have. So far I have ascertained that the stepper motor is clean, closes on shutdown then pulls back a bit. I have adjusted it manually to where it does not over rev and disconnected it. I have cleaned the throttle body and the MAF. There are no air leaks. The whole rig is running really smooth with good economy 13.5l to the 100k at standard height (on coils). There was a mild surging at idle which has all but subsided after cleaning the throttle body. I think if anything the IAC could have been pulling back a bit far, because It is practically at the closed position now. Idle is now at 700 cold up to 900 hot.
    A Nanocom Evo is on the Christmas shopping list. The hotty is a bit tired of the obsession.
    Any thoughts would be cool.
    Thanks guys.
    Irymple, Victoria, Australia
    I may be way off the track but i had a Daihatsu diesel do that once and it had a leather diaphragm on the fuel pump that had perished.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Avoca Beach
    Usually on a 14 CUX the IAC OPENS fully on shutdown. Thsi is to ensur eit gets exercised and doesn't become sticky . Ha ha .
    That is why you get high revving for a while when it gets sticky.
    I think that GEMS would be similar.
    I assume GEMS as you don't state which model.
    On Thor the IAC is much more powerful and a different system of a sleeve valve.
    Look a petrol engine MUST have an air leak if it is idleing fast as the throttle blade "throttles " the air into the engine. Have you checke dthat the throttle blade and area is clean? The only other reason could be excessive advance., or maybe long shot FPR staying rich on GEMS only( maybe not even GEMS).
    Regards Philip A
    Mar 2013
    Tweed Heads NSW
    Anything but the fuel pump!
    Thanks Mick. I'll check it out. I was hoping no-one would say the f word.
    Feb 2010
    Townsville, QLD
    You have probably already checked, but I am going to state the obvious anyway!
    Have you checked all vacuum lines and any of those additional ports on the intake manifold? Even a quick check of the torque of your manifold bolts might bring up something!
    Do the gems v8's run vacuum booster for the brakes? I suppose they would/should be the same as a Thor.
    Keithy
    Mar 2013
    Tweed Heads NSW
    Yep a GEMS, Philip A.
    Sorry bout that. What is FPR? Both myself and the local mech had a good spray, and checked the vacuum lines. Pretty sure not a leak. I also gave the butterfly area a good clean as there was a definite build up in the form of a black ring. That evened out the idle a bit but also raised the idle a tiny bit.
    Cheers.
    Mar 2013
    Tweed Heads NSW
    Hi Keithy
    Yep checked vacuum hoses and sprayed like a tomcat. The intake manifold/valley gasket was changed not long before this started, so I hope they know what they were doing. I did not consider them overly conciencious but they seemed capable. I have not seen anything that looks like a vacuum booster for the brakes, rather I think the accumulator does the same job as well as maintains pressure for the ABS.
    FWIW: surging can be a symptom of a failing throttle positioning sensor (TPS). Presume you have checked the clearance of the throttle cable/cruise control cams as well?
    Avoca Beach
    Fuel Pressure Regulator
    Regards Philip A
    Mar 2013
    Tweed Heads NSW
    Thanks Philip. Hi Hoges.
    TPS did come up in my research, found a manual test to assess the voltages. (Looking forward to the Xmas pressy Nanocom !) I'll know soon enough if it is the TPS as this starts messing with the gearbox in a big way apparently. If by cams you mean the slack in the cables from the accelerator and the cruise control, then yep, they have just a tiny bit of slack in both and are seated. Also the butterfly is closing perpendicular with no gap. Phillip A I'll start researching FPR.
    Thanks guys
