Results 1 to 9 of 9
Thread: prepping disco for roadworthy
    Jul 2008
    Ballarat, Victoria
    If you were in my position, preparing an early discovery for registration, would you:
    1) Get a roadworthy test done on it, to have a definitive list of everything required to get it legal, including some things you didn't realise were needed
    or,
    2) Do the work you think it requires, then take it in for the test, you would think there would be less on the final list, but you also risk changing parts unnecessarily
    Free Again Thanks Dan
    My opinion do what to think it needs then take it in for a test , In my experience they always find something in the chance they might make some money out of you
    Yeah as said
    Do what you know what needs doing and check the normal obvious things , Lights, washers , wipers. But some things like bushes can really be only checked properly when the truck is over the pits.
    When I got my disco done he told me the front hockey stick bushes were ok but had 6 months left in them so he wanted the changed before he would give me the certificate. Which I could not understand , but his face dropped when I told him I would be back that afternoon with them done as I had a front hockey stick all bushes up and ready to go.
    My Disco and two defenders are all the same for bushes so I have a spare set made up at home. So I just went home and swapped them over.
    Think that was just a money making exercise that back fired.
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    May 2010
    brighton, brisbane
    Quote Originally Posted by jazzaD1 View Post
    or,
    If you are not familiar with the vehicle, definitely no. 1 , but get recommendations on the best people to do the job from AULRO members in your area, Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    St Helena,Melbourne
    4.28 MB
    Same as Rangieman said , if you do your own spanner work always do the work you know that needs to be done then get it inspected.
    Guaranteed you will need a new windscreen.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2012
    Bendigo
    get the test. From someone cooperative. THe ones who did my last few were great, I'd get the check done, I'd pay for it, but they would not date it as within reason, I would go back when the items were addressed and they'd complete it then
    May 2009
    Tatura, Vic
    Quote Originally Posted by 1976_michelle View Post
    They can't do that anymore as all RWC's have to be photographed with a date stamp. If they get audited by Vicroads the date of first inspection and the photo will not match.
    Loanrangie. The rules on windscreens aren't as tough as they used to be. My D2's screen 18 months ago easily passed an RWC that a few years ago would not have a hope in hell.
    As for the original question, fix what you know first, as you only have seven days to fix defects, so you want the list short.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Some basics you can check your self before hand.
    1 No warning lights illuminated on dash
    2 No frayed seat belts,
    3 Horn, indicators and lights working, lenses must be unbroken and not faded
    4 Washer and wipers must work ( cheap to install a new set of wiper blade rubbers, they seem to pick on this)
    5 Bad Rips in seats, if ripped cover with a seat cover
    6 Brakes discs and pads, and hand brake must hold,
    7 Mirrors inside and out
    8 Oil leaks ( hard on a land rover) maybe a good pressure wash before
    9 Mud Flaps must be fitted if vehicle had them.
    10 Sun visors , must not hang to block vision
    11 Heater/demister must work to demist windscreen, not sure about back window
    12 Tyre tread and correct tyre size fitted as per manufacturers specs.
    13. spare tyre, must be legal if it is used, and secure, I don't think it's a requirement to have one ????
    14 Major rust
    15 Windscreen depends on how bad its scratched and chipped, they are a little easier on them these days.
    16. Seat bolts under floor pan chassis are secure and not loose.
    17. operation of door locks/catches, must open and close securely
    18. window winders works
    19. Tow ball /hitch not fitted to obsure number plate
    20. Worn steering or suspension components, ie split or torn tie rods and ball joint rubber boots, loose or excessive play in ball joints or tie rods.
    21. uni joints loose
    That's covers a lot of basics you can pre check yourself
    May 2009
    Tatura, Vic
    Not as harsh as they used to be. Oil weep is allowed so long as no oil is dripping on the ground
    Never heard of this one. Not saying you are wrong but where on the compliance plate does it say mud flaps, so how would the tester know?
    Not required. If it is bald remove it.
    Also depends where it is chipped
    Not a requirement. It will be hard to find a tester that that will pass this but I did. My son needed a RWC and when I produced an ADR that said windows do not need to work he argued that it would be a state law.
    Anyhow he brought out the books and he found, "If a vehicle has a ventilation system that allows fresh air to be bought into the cabin, there is no requirement for windows to operate"
    Dave.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
