Results 1 to 10 of 20
Thread: Front drive shaft alignment.
    Oct 2007
    Williamstown, Victoria
    I recently replaced my front uni joint.
    Following the rave instructions I marked shaft alignment points before disasembling, but during the replacement everything got covered in grease and I lost the marks.
    I put it back together but am experiencing a slight vibration while driving, which feels very much like a drive line vibration. While it's not bad, it is a bit annoying.
    I am going to replace the other uni joints to rule them out as they are probably quite old, so while I have it apart again, is there any way to tell the proper front shaft alignment?
    I saw a punch mark on the main shaft, but nothing obvious on the small part to line it up with.
    I had a look on Rave and also did a search but found nothing on this for P38's.
    I read some Land Rovers have the front shaft deliberately a bit out of phase, not sure if that is the case with P38's though.
    Can anyone help with this?
    Cheers, Pete.
    Hi Peter,
    as best I can determine, the front shaft is arranged such that its rear UJ (closest to the T/F case) "leads" the front UJ by 2 splines, with the sliding joint closest to the transfer case...
    This is illustrated in the early edition of RAVE dealing with the RR "Classic" but I couldn't find it repeated in the later RAVE editions for the P38, though it is my understanding the front end alignment is the same for both vehicles. Apparently in the later Classics they pitched the front axle 12 degrees to improve straight line stability and in so doing compensated for the altered UJ thrust angles by changing the UJ phasing as described as well as bolting the elastomeric mass to the front and rear axles to counter the ensuing vibration.... a double cardan shaft is probably the only means of truly eliminating the vibration.
    Oct 2007
    Thanks for that info Hoges, I can work with that!
    Will give it a go over the weekend.
    I know the vibration might be a worn uni joint, but will be good to know the shaft is set properly.
    Cheers, Pete.
    Feb 2013
    Gosford, NSW, Australia
    Hi
    If you are sure the Uni Joints are all cool, you can have the tailshaft dynamically balanced if it still vibrates
    Steve
    Feb 2013
    HI
    Also of course, any slight wear in the splines can cause vibration.
    I have never had an issue with tailshaft vibration on any rover i have owned, it should not vibrate at all
    Steve
    Oct 2007
    Thanks Steve, I'm going to replace the other front uni joint to eliminate that from the list, while I have it apart I'll line up the drive shaft and see how it is from there.
    Failing that I'll do the rear uni's as well, may have to get the raod wheels balanced incase I've lost a weight off a rim.
    Failing that I'll be looking at getting the shaft looked at.
    Cheers, Pete.
    Complete "how to" track vibration... Prop-Shaft Phase
    Jun 2010
    Buderim
    Ive just had my 2000 p38 front propshaft overhauled and balanced.
    When I got it back to my shed for fitting it wouldnt slide in and out. So back to the gearbox shop I went knowing they had put it together incorrectly. The for aft part - hookes joint I think- key in only one way. If you look inside the female side you will see a machined out spline. This ensures it can only go together one way.
    So I insisted that I inspect the splines for damage when they got it apart - It was stuck pretty hard. I inspectd the splines. carefully and luckily no damage, eventhough they had forced it together.
    Interestingly the senior man turned up to take control and said that because it had been miss splined it would need a rebalance now that it was put together correctly.
    However they spray painted over my witness marks which I made on removing from the car - eventhough I said do not spray over these marks.
    So make sure it is splined correctly on reassembly, cause even the specialists get it wrong.
    Also make sure the hookes joint - sliding bit- goes against the transfer case on refitment - you probably know that already.
    Oct 2007
    Interesting peter51, I did notice the inside of the spline did have a gap instead of one of the splines.
    Are you saying it only goes together one way? If so, that would make a lot of sense, as it would be all too easy to assemble the wrong way, as I could not see any marks to line anything up with.
    It was hard trying to refit the shaft from underneath, I noticed it would not go on until I rotated the shaft around, then it would slide on ok. So maybe the shaft is on the correct way and the other uni joint is the culprit.
    I may have to take the shaft back off, will be easier to see when not laying under the car.
    Jun 2010
    Buderim
    yes it only goes together one way in order to maintain the phasing. I cant tell u if my vibration has been solved because I have a coolant leak and cannot test drive the vehicle untill I get a new o ring.
    Any minor slop in the uni will cause the prop shaft yokes to not follow their correct longitudinal axis - for want of a better description the yoke is thrown eccentrically each revolution.
