Results 1 to 10 of 11
Thread: '85 110 - fuel tank not venting
    Geelong, VIC
    I've got an issue with the fuel tank on my County not venting. When I stop to fuel up after a decent drive there's a definite suction on the tank cap, and I've noticed on occasions that I get a loud "donk" sound from the tank about an hour on the highway with a full tank. Presumably one of the flat panels on the tank oil-canning as it gets sucked in.
    Its a long range tank, but everything connects back to the filler neck like a standard tank. I'm guessing that the venting must be meant to happen at the cap as there is no other way I can see for air to enter.Is that correct or am I missing something?
    If it IS via the cap, any likely causes of it not working?
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Nov 2011
    My 85 County V8 did this eventually it will have trouble sucking fuel through if the pressure is great enough.
    I found that the expansion tank that is mounted up behind the rear drivers wheel was blocked, after I pulled it out and cleaned all the mud out never had a problem with pressurisation since.
    Richard
    Aussie Expat in NZ
    Do you have a spare fuel cap to try?
    Judo's Avatar
    Judo is offline ChatterBox Silver Subscriber
    Feb 2012
    Parkdale, Melbourne
    Interesting. I assume it hasn't always done it? It's funny how someone starts a thread for an "issue" which my vehicle has always done. I'm sure my Disco makes a good suction sound when I take the cap off. Always has... The cap itself could be key though as my cap has "unleaded" written on it, but it's a TDI, so obviously not the original. It has a 120L longer ranger tank.
    I'm not sure about the side popping in and out though... I hear too many random noises to know if one of them is this.
    Now I'm also interested to know if some suction is normal now!
    Still, if it ain't broken, don't fix it. My Disco runs fine.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Geelong, VIC
    Quote Originally Posted by Judo View Post
    Interesting. My County is now a diesel, but was originally a V8. I definitely doesn't have any expansion tank as Richard described. I'm now wondering if there is a different arrangement for the diesel and if its perhaps been overlooked in the original conversion.
    I'm not aware of it causing me any issues but it just doesn't feel right that the tank should end up with that much vacuum.
    Looking in the later Defender parts manual there are 2 types of tank caps - vented and non-vented. I'm guessing the non-vented variety need to have a vent arrangement somewhere in the tank breather itself.
    The plot thickens......
    Steve
    schuy1 Guest
    Just have to be aware that some fuel caps are vented and other models are not. I have a '96 build Tdi and I had to get a new cap at 1 stage. I was sent a cap, fitted it and off I went, 300 kims later I got starvation symptoms! after some head scratching I found the cap was not vented as needed on that tank! It had suctioned on so hard I had trouble removing it and it had also oilcanned the bottom of the tank up! It still has a dent in it . pre '94 seems to be tank vented, post appears to be cap vented.
    Cheers Scott
    Judo's Avatar
    Feb 2012
    Parkdale, Melbourne
    Interesting. Was that a Defender or Disco Scott?
    Just did a few searches and it seems there is often 2 types of breathers/vents.
    1. The filler tube incorporates a tank breather which allows air and fuel vapour displaced from the tank when rapidly filling to vent to atmosphere via the filler neck.
    2. A breather within the tank that is used as fuel is used by engine. Small tube.
    Obviously most vehicles have (1) but doesn't tell you one way or the other about (2).
    If you don't have (2) then I would think you need a vented cap.
    In the Disco TDI workshop manual it says.
    Fuel system
    A 89 litre fuel tank is mounted at the rear of the
    vehicle beneath the load space floor. The tank is
    vented by a 2 way valve in the filler cap.
    Looks like I have the wrong cap at least...
    Yours is a bit tricky with your 3 different engines Steve. If you can't find type (2) breather though, sounds like you need a new vented cap.
    - Justin
    The cap on your county is a non vented type, as described earlier the original county vented through the over flow tank. To prevent the tank pressurising previously I had a breather hose that equalised the pressure that ran up higher than the tank.
    Adrian
    Geelong, VIC
    OK - all makes sense now.
    Have just ordered a couple of motorbike tank one-way vent valves from ebay. Figure they'd do the venting job, and hopefully stop the fuel running out in the unfortunate event that we find ourselves dirty side up
    Steve
    Feb 2010
    TANK
    Didnt do it when it was in the Defender Steve.
