Results 1 to 4 of 4
Thread: acco gas conversion
    acco gas conversion
    anyone had experience on putting an acco on gas?
    Crafers West South Australia
    Which engine? I've put a couple of 345 V8s (horse trucks) on gas, didn't go badly.
    thanks for the quick reply. 345 n probably with headers and allison transmission
    Yeah well they're just a typical lump of yank iron, they eventually burn valves if you don't take precautions for heavy duty use (upper cylinder lube or hardened seats) and run a typical Holley sized carby that's dead easy to get a mixer for. My fun trick was to gut the points dissy and install the guts of a Holden V8 electronic dissy, including machining down the case to take a stocky Holden cap instead of the yankee one. HEI ignition works wonders for LPG on these just like on any other common V8.
