Thread: Vista laptop upgrade to Win 8
    May 2003
    On The Road
    can I just upgrade it?
    or do I have to do a clean install?
    Will I be able to keep settings and documents?
    will the laptop "find any wi-fi" still work?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    should upgrade just fine
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Bracken Ridge, Qld
    if you really want Windows 8.
    I have a Windows phone and thats put me off it for life.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    best version of windows since 3.11!
    sheerluck Guest
    Quote Originally Posted by incisor View Post
    What, Vista?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by sheerluck View Post
    What, Vista?
    win 8
    not that i disliked vista that much as it was stable but just a little unfriendly.
    Bracken Ridge, Qld
    about time somebody mentions how good DOS was, surely......
    gone
    1996 Discovery 1
    current
    Quote Originally Posted by VladTepes View Post
    So good you can get DOS emulation for OSX, iOS, android, windows, blackberry, linux and probably other stuff as well. Must be a demand for it, surely. How else do people keep their Windows 3.1 running?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Bangor, NSW
    Before you jump onto Win8, make sure the laptop you're upgrading has Win8 support from the maker. Otherwise, you will have Win8 and not many drivers available.
    Jul 2013
    Alice Springs, NT
    There are some things to consider -
    *If you have 32bit Windows Vista you have to buy the actual disc if you want to upgrade to 64bit Windows 8 else you need to do a clean install.
    * If you have 32bit and happy with 32bit Win 8 - you can just use the digital without a clean install.
    * If you have 64bit windows vista you can just use the digital upgrade to get 64bit Windows 8 without a clean install.
    Also depends on what versions you want - pro vs home etc... Also be mindful that not all you software may be windows 8 compliant (also windows 8.1 now out with is a free update from 8).
    Wifi should work but you may have to re-enter passwords.
    Hope that helps
