Results 1 to 10 of 12
Thread: Tyres are ordered, Any tips?
    Sep 2012
    Tuncurry
    My disco 93 3.5 v8 now has 145ish liters fillable of gas, and I have just ordered 265/75/r16 set (2 inch dobinson lift kit is on the rover) im guessing I will have to get in and cut around the arches back abit will be able to see what has to go when the tyres are on, tyres will be bfg km2's.
    pic of gas and stuff.
    Apr 2010
    Emerald, Vic
    Question. Are those dickie seats still usable? If not might be an idea to put a raised floor to cover the tank and get your cargo area back. Although slightly smaller.One thing i can advise about the tyres and it is the most obvious one. Check the pressures every now and then, don't ignore them like I have the last few months. Noticed the other day the left rear was looking a little down, but thought it was due to the load in the back. Checked and it was down to 19PSI. No puntures just s strange one. Always seems to be that side since day 1 almost 15 yrs ago.
    Douglas Park, NSW
    Planning to go off road?
    If so, my tip is to ditch the LR towbar & stick on a Hayman Reese/ARB type. That thing is a plough .
    St Helena,Melbourne
    4.28 MB
    With 265/75's you will need flares if you plan on getting it flexing offroad.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Western Victoria
    Quote Originally Posted by luke68 View Post
    Not that strange, really. Did you know tyres are porous?
    I didn't until a very well known tyre importer/manufacturer/wholesaler/retailer spoke "tyres" at a club meeting.
    Jul 2008
    Ballarat, Victoria
    The lpg tanks seem to be the biggest plough of the lot so a different towbar won't make a whole lot of difference!
    Douglas Park, NSW
    Quote Originally Posted by jazzaD1 View Post
    Aah, but the tank is a 'smooth' plough (and a bit further forward).
    St Helena,Melbourne
    4.28 MB
    I had the same twin tank setup in my old rangie and didnt find that they hindered the clearance at all, i think there was about only about 50mm difference from original tank to lpg tanks.
    1974 VW Kombi bus
    Sep 2012
    Tuncurry
    Yeah I have no use for the tow bar, its going to be coming fully off, the tanks sit fairly higher then the diff and the tow bar so should not be a problem, the tires will just ensure that bit of extra clearance and traction and bigger foot print to cope with the extra weight, thanks for the tips. I have already removed the seats in the back :-D you do surprisingly get more room then you think, currently looking for something to go over the tanks. Current tires are 205/r16, does anyone know the speedo difference? and can the speedo be adjusted?
    Also is there any good place to get the flares from at a good price?
    Sep 2013
    Whyalla
    Quote Originally Posted by Flemo View Post
    Heres a decent price for a set of flares
    LRD155 | Plastic Wheel Arch Kit - 5dr with cut out for side mouldings
    and if you dont have side mouldings
    LRD156 | Plastic Wheel Arch Kit - 5dr no cut out
