Thread: Fitting a radio in TD5 Discovery
    harryw Guest
    Just acquired a TD5 and intend bringing across a UHF radio from previous vehicle.
    Any suggestions as to the best place to install or are there any aftermarket consoles available
    harry
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Welcome to AULRO!
    Hope you find the place usefull...
    cant help you with the radio sorry, but if you put your location in your profile using the profile link above you may get someone local to you that may be able to assist you.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Pilbara WA
    Welcome to AULRO
    Not sure about the defender's but I have a after market consoul in my Disco.
    Fit's above the radio and can hold two comm unit's or what ever you wish it too. Great little unit.
    Send a private message to Pirate, he has a defender with radio is fitted, I just cant remember where he mounted it.
    There are two types of people in this world, good and bad. The good sleep better, but the bad seem to enjoy the waking hours
    MylesC Guest
    Try Opposite Lock for a dash pod. I have one. Good unit and easy to fit.
    South Yundreup,WA.
    Either consoles.com or outback 4wd accessories have consoles.
    Mandurah WA
    Harry
    I have a Defender TD5 so do not have to cope with the acres of plastic when mounting gear.
    I have a remote head GME UHF unit. I have mounted the trancever body under the steering column (between ones legs 8O ) and the head unit just the left of the instrument cluster (the support bracket screws up underneath the dash return in front of the fresh air vent).
    I am running a remote speaker to the top of the B pillar on the drivers side (ie pointin in ear so I can hear radio with the engine running!!!! :roll: )
    Now if anyone has a good idea on where to mount the trancever of a HF unit I would like to hear. I am still install my Codan NGT.
    Good luck
    May 2003
    On The Road
    Hi Harryw,
    you dont say Disco or defender?
    I put mine on the back of the centre cubby box, small oval extension speaker on front of cubby box below arm rest, works fine,,
    9db spring steel aeriel on bull bar right in navigators line of sight :wink:
    At the same time had the guy put an AMFM aeriel on the drivers side of the bullbar.
    The standard radio antenna placement on the early Disco's was not um, er, well thought out.
