                                                7th December 2003, 08:29 AM
			Timing degress for LPG???
					Anyone running Duel fuel. LPG and Petrol/
 What have you set your timing to?
 Std on the Aus spec Disco 3.9 EFI is 2 deg btdc.
 I hear that spark plugs should be gapped differently ans timing advanced.
 On LPG joint says advance to 8deg, another says leave std.?
                                                8th December 2003, 09:15 PM
					Advance for LPG to 8 maybe even 10. If you run on petrol and it pings you will have to find a compromise between.
 Its said thet disco timing marks arnt acurate anyway. You need to do a TDC check to find 0 degrees.
 Bazzle [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
                                                11th December 2003, 07:22 PM
			LPG tune
					Advance is important - agree about 8 -10 degrees.   Check that the vac advance unit is actually working, too.   Often fail....
 Plugs - no change to gap, but a different heat range if LPG is preferred fuel.   Talk to your local LPG dude.
                                                11th December 2003, 07:48 PM
                                                #4
					I checked NGK plug site and they reccomend I range cloder plug and also reccomend regapping 1mm closer on their plugs.
 Vacuum advance is fine. Bought a reco not so long ago.
 I agree I have heard that Rover TDC marks are not always accurate.
