                                                23rd October 2013, 04:53 PM
			cyclone thingy
					hi all ive been chasing down a oil leak on my tdi 98 110 seams to be coming out of the bottom of the cyclone piece that comes out of the rocker cover its weeping out around the bottom piece around the lip
 above the hose then running down not a lot, done 500ks since the clean down but I can see it starting to pool around the top of the hose that feeds into the block anyone got the same prob cheers in advance
                                                23rd October 2013, 06:05 PM
					Have you tried replacing the O-rings?
                                                23rd October 2013, 06:29 PM
					Yep check the 'o'ring where the breather bolts to the tappet cover , also check both the hoses coming off it as they go hard & crack.
                                                23rd October 2013, 08:07 PM
                                                #4
			cyclone breather
					yes it is definitely coming out of where the barrel meets the join at the bottom of the breather itself its a after market breather don't know if landrover still make them it is a reasonably new breather maybe they all leak
                                                24th October 2013, 06:19 PM
                                                #5
