Thread: Oil seal help
    Jul 2013
    ravenswood, Western Australia
    Oil seal help
    hi all,
    i have just removed the front output shaft flange and the cover plate behind that on the gear box as my landy sprung a leak.
    my question is, how do you remove the oil seal?
    (see photo showing the seal in question with a green arrow pointing to the offending seal)
    it appears there is a metal ring holding it in??
    cheers for your help and time
    Josh
    The book says to "press out oil seal", but a brass drift will almost certainly work. The "metal ring" is part of the oil seal; they all used to be like that!
    Sandgate, Brisbane
    brass drift & hit it a lot
    Jul 2013
    which way should i hit it? down towards the front of the housing or flip it over and hit down ?
    cheers again
    Quote Originally Posted by SII Josh View Post
    cheers again
    It comes out away from the transfer case, towards the prop shaft. If it is hard to move, try heating it up by putting it in boiling water for a few minutes - the alloy expands more than the steel does. (but this should not be necessary)
    Aug 2012
    northmead
    A good trick that I was shown was to drill a hole in the rim of the seal and use a panel beaters slide hammer to pull it out. You screw the tip of the slide hammer into the hole and the seal comes out easily with a couple of slides.
    Jul 2013
    cheers for the help people, i took it in to work and we put it through the robo wash (parts cleaner that washes parts at 80 degrees temp) machine a few times to get it warm then we put it in the press machine and slowly pushed it out.
    first time i have seen a leather seal on the landy too
    Almost certainly they all were when it was assembled! May be the only original one there.
    Leather ones seem to seal better, but will harden and leak if not used regularly.
    darwin, nt
    Check your drive flange hasn't been badly grooved - no new seal in the world will stop a leak if it is, you'll need to renew it or fit a Speedi-Sleeve.
    Dan.
    69 2A 88" pet4 (still in disguise), 68 2B FC pet6 (still resting quietly), plus 14 other parts/project cars (1xS2, 6xS2As, 7xS3s).
    Jul 2013
    will have a look see today as its still in bits.
