Results 1 to 10 of 17
Thread: L322 Steering Column
    Hi guys,
    I have managed to negotiate a settlement with the car dealership to fix my steering column reach motor. I have taken it in to a local mechanic (Land Rover specialist) and he seems to think I need a complete new column to fix the reach function.
    Does anyone here know if it is possible to hav the existing column reconditioned or is there a company who sells reconditioned columns. I believe from the mechanic a new column is about $1200 and about $300 to fit. The amount I got back from the dealer only covers half of this so I am hoping to try and reduce this cost.
    Any help or guidance would be very appreciated!
    Cheers, Brad
    Mar 2007
    Brad
    Is it definitely the motor or it just doesn't move ? sometimes the 13mm nut at the end of the drive comes off, just undo the 3 torx screws on the column surround and manually turn back onto the shaft or it could be the tabs see below.
    fullfatrr.com - View topic - Steering Column Tilt Broken
    or
    fullfatrr.com - View topic - Steering column adjuster
    Laurie
    I can hear the motor operating but the column does not move. The diagnosis from the mechanic (without pulling everything apart) is that it is most likely a stripped nut within the column.
    I have only recently purchased the car so I will need to (learn to) pull apart the dash it seems to get to the column to take a bit of a look.
    Mar 2007
    Brad
    Hopefully that the motor is still working, the nut has come off If you do inspect the shaft make sure it has plenty of grease as lack there of has caused others to stop working.
    Laurie
    Aug 2010
    Sunbury, VIC
    If it has stripped the nut, then it is a new column. Hopefully it has just come off...
    Feb 2009
    Bondi
    Steering adjustment
    Hi All
    I have a similar problem.
    I recently tried to adjust the steering and heard what sounded like a nut, fall into the steering plastic surround.
    The steering, forward and back adjustment has now ceased...
    Does this sound familiar, to anyone out there ???
    Cheers Paul
    Mar 2007
    Paul
    It does sound like the nut has dropped off ! I hope for your sake it's not stripped. Just grease the shaft and tighten the nut back on and all should be good.
    Laurie
    Feb 2009
    Bondi
    Steering adjustment
    Thanks Laurie
    Pulled off the panel that sits above the pedals, half of a white bracket fell out and something that looks like a cylinder, with wires attached, was resting on the panel.
    Any ideas ?
    Paul
    Mar 2007
    Paul
    It sounds like your describing the bracket that holds the motor has broken in half and the cylinder you see is the motor itself. That second link I posted above shows this and hold the motor in with some cable ties will hold it in place.
    Laurie
    Feb 2009
    Bondi
    Steering adjustment
    Hi Laurie
    Yes that link was a great help, and the plastic bracket has indeed broken in two.
    Tried getting to it from the drivers footwell, but really need to remove the whole panel to get better access...
    The plastic wire ties seem like an easy fix. Do you know if that bracket has a part number ?
    Cheers Paul
