Results 1 to 10 of 13
Thread: perentie roof cage
    Sorrento Victoria
    perentie roof cage
    I recently purchased a perentie softtop but it's missing the roofrack/cage -anyone know where i can get one?
    Feb 2005
    check if the rivnuts are still servicable, my bet is one or a couple are stuffed therefore the cage was left off
    Hay Point
    Quote Originally Posted by mattmac View Post
    Easy enough to make one up with a bit of RHS, a tube bender and some weldmesh. Get the measurements from another vehicle.
    Cheers......Brian
    1985 110 V8 County
    Jan 2009
    Medowie, NSW
    Perentie roof cage
    I've taken the mesh roof panel off my GS Cargo Perentie to remove the canvas for a minor repair and to make it easier to clean the mildew off.
    My cage was fixed by 4 / M8 or 5/16'' cup-head square-shank bolts; 2 bolts up through the roll hoop at the front and 2 up through the rear canopy frame. Bolts are if slightly different lengths due to the cleat and hole arrangements of the mesh roof panel. There is a mating square recess in the two canopy frames to engage the bolt shanks to prevent the bolt shanks from turning. Not sure where Kelvin's (weeds) reference to rivnuts comes into play; I just assumed anchoring with the cup-head bolts was the O/E method.
    On top of the canopy are rubber bushes on top of which the roof panel cleats and holes sit, with the panel restrained by washers and hex nuts.
    When my mesh roof panel goes back on I will be replacing the bolts with new galvanised bolts & nuts, replacing the rubber bushes, and in addition to the tensioning hex nut I'll be fitting galvanised eyebolts to the ends of the bolts as tie-off points.
    Figured there was no harm in this as I already can't fit in most covered carparks
    Feb 2005
    Quote Originally Posted by cummo View Post
    umm, i will have to refresh my memory, i cannot recall bolts going right through the front ROP's.
    my last job in chocko's was helping the truckies replace some canopies and i am certain i have to cut the head of the bolt off and fit riv-nuts. pretty sure there was an instruction to follow. its been a while and a few drinks so i would have to look at one.
    Dec 2008
    wollondilly
    Both the front and rear bar on mine have 8mm Riv-nuts for the rack.
    Feb 2005
    Quote Originally Posted by jackz View Post
    phew....thought i was going crazy
    if bolts are going right through the ROPS than i guess somebody has taken the easy route as you should drill or weld ROPS....well the front one anyway
    Dec 2008
    wollondilly
    Drilling it is definitely not recommended! =-O
    Sep 2006
    Northern Beaches
    There are probably dozens left lying around at army bases around the country, leaning up against something, or hidden on top of something. Just like cargo barriers from white fleet.
    Jeff
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    if bolts are going right through the ROPS than i guess somebody has taken the easy route as you should NOT drill or weld ROPS....well the front one anyway
    Fixed it for ya, weeds.
    Cheers, BDave.
    Replace "You are...!", with "Are you...?"
    Army Land Rover Buyers Guide.
    buymilitaryvehicles.com
    Reunited with RFSV 51 680, 'Sleazy'!!
    '00 VeryDisco TD5 Auto,
    Nanocom Evo for D2 TD5 and Puma
    Gone:RFSV, 51-699, Carryall 48-358.
