Results 1 to 8 of 8
Thread: Vehicle Showers
    May 2002
    Heathcote (in "The Shire")
    Vehicle Showers
    For any one thats got a vehicle mounted shower (Glind, Twine, McPauls etc).
    I recently found a 9 metre layflat hose on a reel suitable to use with the shower so you can get further away from the creek/vehicle etc has standard clik fittings.
    Approx $30 from Bunnings hardware
    Box approx 300x300x30
    Bushie
    Pilbara WA
    Have seen this hose.
    Looks nice and strong too, also take's up very little space.
    Nice idea Bushie
    There are two types of people in this world, good and bad. The good sleep better, but the bad seem to enjoy the waking hours
    May 2002
    The space was the main reason for buying it but price had a bit to do with it especially as some of the caravan type places were asking upto $120 for the equivalent thing.
    Bushie
    Bracken Ridge, Qld
    I've always wondered about those showers - how do they work ?
    If they have a heat exchanger doesn't this mean the engine has to be hot / running for a length of time ?
    I reckon the wife would love me if I got her one for camping BUT finding the fresh water... that's a whole other issue I guess.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Caboolture
    Next question, is the pump strong enough to suck water through 30 ft of hose.
    May 2002
    Originally posted by Mick&#045;Kelly+--><div class='quotetop'>QUOTE(Mick&#045;Kelly)</div><div class='quotemain'>Next question, is the pump strong enough to suck water through 30 ft of hose.[/b]
    Not intended for the suction side of the pump as it wouldn't work that way (hose would collapse under suction) but more for the dischage side so you can get a bit further away from the vehicle (or creek etc), its also handy for filling a water tank in the back.
    <!--QuoteBegin-VladTepes
    [/quote]
    The engine has to run at least until its warm (this varies with the air temp and temp of the water). I've found that a quick 10 min run up the track etc is more efficient than idling away.
    Thw mrs loves it and I would rate it as one of the best accessories I've put on the vehicle.
    Bushie
    Cessnock NSW
    We have one fitted to our 110 a Glind that is, I fitted it about 6 years ago, it has a fantastic pump my wife loves the unit especially when up on Stockton beach to wash off the salty water and sand out of swimming costume, we generally use 20litre plastic J/cans with H2o from home, I have pumped water from tanks and it works fine, you do have to be careful when using it though 'cause if you turn off the shower at the nozzle and your engine is running you will be severly scalded. I wouldn't be without mine, they are now an expensive item if setting up for a long trip around Oz
    Bracken Ridge, Qld
    NOW an expensive item or NOT an expensive item...
    gone
    1996 Discovery 1
    current
