Results 1 to 10 of 16
Thread: Adding extra brake vacuum capacity for increased braking
    Jul 2008
    Victoria
    I have a 130 with just adequate brakes at sea level.
    We are heading to Sth America next year and will be driving at 4000m plus according to those who know more about the place than I currently do.
    Reading Kym Bolton's "Goanna Tracks" - Kym is currently in Sth America - he has had an extra vacuum tank and pump fitted to his Canter to increase braking efficiency at altitude.
    What do you think! Can I do something similar on my 130?
    Jan 2010
    Perth S/W
    I find the brakes on my 97 130 very good . I have replaced the vac pump & booster , standard stuff , Do you know the condition of yours ? If all is in good nick I am surprised you are not happy with them .
    Judo's Avatar
    Judo is offline ChatterBox Silver Subscriber
    Feb 2012
    Parkdale, Melbourne
    I'm not sure that a vacuum tank will help. You need a better booster.
    If I picture a 1L tank at 50psi or a 100L tank at 50psi - the volume of the tank is not giving any difference in pressure.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    JDNSW's Avatar
    The brakes on the Defender are usually considered adequate. In what way do you feel they are inadequate? Pedal pressure too high? Poor braking performance? Brake fade?
    None of these will be affected by an increased vacuum storage. The only thing that will be improved by extra vacuum storage is the ability to make multiple brake applications with the engine idling or off, and this may indeed be an advantage in mountain driving.
    However, what may be worth considering is changing to a booster with a larger diaphragm area (such as a dual diaphragm one), as the assist force depends on the atmospheric pressure x diaphragm area, and at 4000m the atmospheric pressure, and hence braking assistance will be only be about 60% what it is at sea level.
    Either or both can be fitted, but you would need to talk to a brake expert, who should be able to advise what is available that could be fitted.
    Jul 2008
    Victoria
    Better brakes quest
    Thanks for the feedback.
    My 1996 130 has a camper on the back with an all up weight of 3000kg. Breaking is adequate under normal circumstances but the pedal goes to the floor in an emergency, soil your pants, situation. No way does it go near to a lock up. Not that that is a desired outcome. But the pedal hitting the deck is a worry. I've had this truck for 18 years and I never remember the brakes being real flash!
    I have done all the usual. Bleed the system, new pads, new rotors not long ago.
    Since my post I have read that the servo assist can develop hairline cracks but I have yet to investigate this further.
    I had a soil your pants moment coming down from Thredbo a few years back, total loss of brakes, so the Andes will demand that I improve current performance. Other wise there could well be another cross on the Death Road in Bolivia.
    Jan 2010
    Perth S/W
    There is a 12v vac pump option , don't know if it would suit , try summit racing ? for details . they are available locally at speed shops etc .
    Torres Straits
    My 1996 130 + Bleed the system, new pads, new rotors not long ago = bad brakes
    your answer is:
    Get someone to jump the pedal while you watch the booster closely. At the ridge where the master is bolted you most likely will see a crack leaking all your hard hearned vacuum to atmo.
    The problem is a brand new booster will likely crack before you even get to the death road!
    It seems that the manufacturers have forgotten how to make a long lasting booster,
    I would look to retrofit or go the tightarse but effective option like me.
    I took two hairline cracked boosters. I carefully turned the face and rolled edge out of one and then aligned it to the second booster. Glued the two pieces together with high grade Sikka.
    So now there is no flex at the face. And no leaking vacuum equals good brakes.
    And btw - a Canter needs more than just a booster upgrade to provide stopping power. Those things bring the suck when you want to stop!
    Steve
    May 2012
    Boulder, CO
    Beautiful truck! I'd say do a full brake service; then see if you need additional braking.
    I find the standard brakes at altitude, here in Colorado, are fine.
    Oct 2012
    FNQ
    Loss of vacuum should only mean a hard pedal something else is wrong if the pedal hits the floor I would fit stainless braided hoses reco the MC and callipers and altho the poor cousin of engine braking consider fitting an exhaust brake
    Oct 2007
    Agree that it doesn't sound right & best to sort that out first. If you are contemplating some sort of upgrade to handle a lot more brake pedal work, it might be worth considering exhaust brakes.
