21st January 2004, 07:00 AM
Slow to select reverse
In the mornings my auto box will sometimes take up to twenty seconds before it transmits drive (only in reverse). I can come up with several reasons why this is happening. However before I make a noise about it to the dealer. Does anyone else suffer this ? Is it normal (for this model..... as every other car I've had in the past this would have indicated a problem.)
21st January 2004, 11:25 AM
What car do you drive?
Irrespective of the car, this is a problem. The most likely cause is low ATF level. If the ATF is full then there is a much worse problem that would require dis-assembly of the transmission. Best done by the experts.
21st January 2004, 07:24 PM
Juddo,
Good to see an early "Overlander" on this site. Welcome.
Mahn
23rd January 2004, 08:24 AM
#4
Thanks Mahn. Just unfortunate I did not find this place sooner. But I have not had a lot of internet time of late due to work and study. Anyway, it is great to be here.
