Thread: X MEMBER CLEARANCE SERIES2
    May 2003
    where ever I fall asleep ,Queensland
    was wondering if someone (probably rocket! :roll: )could tell me why the bellhousng /x member clearance is like minimal if not nothing ?i have jacked up both front of motor and rear of gearbox and not found any signs of a broken mount ,is there a way to adjust the mounts on the body/motor/gearbox as i think this mite be contributing a slight bit of body noise? :?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    what do you call no gap?
    1/2" ?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    well i tried to put a small piece of rubber mat in there and had to lever the gearbox up to fit it in ,clearance would be less than 5 mill :!:
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    that is too close [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
    i have seen many conversions that do come that close.
    all you can do is pack the mounts with shims where needed and get a happy medium if you can.
    Jun 2003
    Launceston, Tasmania
    On a similar topic, my front engine mounts are too high, is there an easy way to lowwer them? I'm hesitant to get thinner parts for fear of the vibrations cracking the engine mounts. Am I better to get lowwer engine mounts?
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    May 2003
    [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] I'll swap my lowies for your highies!!!!!
    sounds sorta strange and wierd dont it????? :?
    Oct 2003
    Godwin Beach Qld
    X-member clearance
    Hi Ferno
    Sounds like you may have the wrong engine mounts in the front, there is a difference between the petrol and diesel, the 21/4 petrol front mounts are P/n NRC 2054 (round steel/rubber/steel,) the rear mounts NRC2053 (round steel/rubber/steel, slightly smaller dia.) the front mounts can be used in the rear /g'box position, the diesel mounts are usually square and not as tall to better absorb the diesel vibrations, with the correct mountings you should get at least 1/2 inch between g/box and x-member [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] these mounts should be approximately 21/2inches high from memory
