                                                15th November 2013, 07:48 PM
			2.2 Decat
					Hey all, I know you can purchase a TF de cat and down pipe and muffler box removal..
 But I was wondering if it would be detrimental to just fab up the piping? I just figure it would be cheaper to turn the stock exhaust into a straight pipe. Mainly the same idea as buying a TF piping kit only getting the local exhaust place to do it
 how much louder does it get? I think I read somewhere it should make the engien run just a little cooler?
                                                15th November 2013, 08:04 PM
					I have heard that there is no advantage to this procedure with a 2.2, indeed, I've heard that it could even be slightly detrimental performance wise, let alone what will happen if you get caught in a roadside EPA check.
 Cheers, Pickles.
                                                15th November 2013, 08:35 PM
					I am also interested in doing the same.... the 2.2 uses a vband where as the 2.4 used a homo flange design so hopefully the 2.2 would be easier...I want to remove everything bar the rear resinator...I have been told that it will go into limp mode however I have had a different response from a reputable tuner from England..from a performance perspective I cannot see how it would be detrimental to performance however ya never know with all this computer garbage.
                                                16th November 2013, 07:05 AM
                                                #4
					Looks like i should wait for someone to try it before i do!! Lol
 Sent from my GT-N7000 using AULRO mobile app
