Thread: disco 1 rims on perentie
    Sorrento Victoria
    i was wondering if dynamic 16x7 disco 1 rims with 265/75 tyres will fit on a perentie okay.
    LandroverScott Guest
    Hi Mattmac,
    What are you doing with your RFSV perentie split rims? do you want to swap for perentie rims or sell or are you keeping them?
    regards
    will fit, not legal, wrong load rate.
    Adelaide Hills
    What is the required rating? I have 5 dynamic rims that are rated at 1200KG and one that I got for a second spare that is rated at 1400 KG
    Jim.
    I'll have to dig through the books again but Im pretty sure its 1400kg+..
    the prerentie rim is 16x6 so you may find the offset is also wrong.
    based on axle weights you would be able to run the 1200kg items legally on anything but the heavyweights (6x6/RFSV types) they need the minimum 1400's due to rear axle weight.
