Results 1 to 4 of 4
Thread: gearbox oil
    Sorrento Victoria
    Lightbulb gearbox oil
    I've just purchased a perentie with the Lt95 box- I'm assuming the army used standard diesel engine oil/same as for isuzu? In my old county i was recommended to use Castrol VMX-80 - should i change the oil to VMX-80?
    Last edited by Mick_Marsh; 21st November 2013 at 09:00 AM. Reason: to be merged with http://www.aulro.com/afvb/military-land-rovers/183981-oils-cargo-perentie.html
    Jan 2008
    Nowra NSW
    Engine oil and Castrol VMX 80 will both work.
    The VMX 80 seems to let the gear changes be a bit smoother.
    Western Victoria
    Sorrento Victoria
    In my perentie manual it specifies OMD115 for gearbox and Castrol FMX for transfer case which is apparently a semi-synthetic engine oil - seems strange they would specify 2 different oils if the oil migrates between gearbox and transfer case? I assume it would be best to use just one type of oil like RX super or VMX80.
