Thread: Bearing shrinkage
    Sep 2006
    Northern Beaches
    Bearing shrinkage
    I am turning a bearing housing for the rear wheel of my race sidecar, and want to know how much do bearings shrink if you chill them? The old housing was a loose fit and it shouldn't have been.
    Start with a billet of 7075-T6
    Make lots of swarf.
    The bearing is on the right. 1 inch inner 2 inch outer.
    Jeff
    Hay Point
    I have never measured the difference after chilling as you have to get it installed asap as it returns to original spec pretty quick, but it does make a tight bearing slip in pretty easy.
    Cheers......Brian
    1985 110 V8 County
    I would have thought the amount that a steel bearing would shrink if put in the freezer alot less than the expansion of a aluminium housing if heated.
    I put some standard LR wheel bearing cups in the freezer to shrink for installing in the hub. IMO it did not make bugger all diference, if anything the condensation was a PITA.
    May 2003
    On The Road
    Sep 2013
    toowoomba
    I had to install a boss on a 5" shaft, 6thou interference fit, chilled the shaft with liquid nitrogen and got the boss to 160℃ on a hotplate and they slid together fairly easily with minimal persuasion,
    Getting the old boss off was another story, 80tonne ram on porta power and a LOT of heat.....
    May 2003
    On The Road
    yep,,
    with interference fits you MUST be sure the first time,,,
    Crafers West South Australia
    Most shaft bearings I have met have a slight clearance in the housing. This allows the outer race to creep and equalise wear around the whole ring. If you're going for a press fit make sure your bearing is toleranced for same.
