Results 1 to 10 of 17
Thread: Holden engine conversion kits?
    Jun 2003
    Launceston, Tasmania
    OK, who manafactures the holden engine conversion kits?
    I am sick of the engine being mounted at the wrong angle, and i'm going to get it sorted out.
    I suspect that it is the fault of the engine mounts that are too tall, so the easiest way to fix it would obviously to replace those with the correct item, but I don't know where to look for them :?
    Anyone?
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    every man and his dog did [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
    what mounts do you have on motor :-
    round?
    square?
    height?
    on gearbox :-
    round?
    square?
    height?
    do you want to go up or down
    at motor ?
    at gearbox ?
    come on man, spill them beans [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    where ever I fall asleep ,Queensland
    [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] so many questions!!!!!
    simple solution, just put a jack under the motor and when it's level just weld some reo rod in place ,never have to worry about broken mounts again!!!!!!!
    hahahahahahahahahahah
    just kidding guys!!!
    although i have done it once on a demo derby vehicle , talk about reverberations!!!! 8O [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    Jun 2003
    Ok, more details then.
    It appears that the front mounts are too high up. Of course it may be that the rear ones are too low, but that is unlikely.
    The result is that the engine has a nose up tilt, and the driveshaft is VERY close to the chassis where it goes through that hole. In fact, when braking downhill when empty it rubs on the bottom, well it used to, the plate that it rubbed on is mostly gone now, although I have been driving more gently.
    The mounts themselves look like cast pieces (not welded), not sure about what material, maybe steel or aluminium. Then the usual rubbers between the mount and the engine etc. I considered replacing the rubbers with thinner ones, but I was worried about cracking the mounts.
    1994 Discovery TDi
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    but what shape and height mount rubbers do you already have where?
    Jun 2003
    Umm, they are round ones between the mount and the engine, about err not sure about the dimensions, i'll grab a measuring tape in my lunch break and check it out. I'll get back to you then, I might even get some pics over the weekend.
    1994 Discovery TDi
    Goolwa SA - but top ender forever
    Phoenix
    from memory there are three good adaptor manufacturers in Oz, again I think all three were in Queensland, they are Dellows, Hadfields and Marks adaptors. I dont have any phone numbers any more but they would be who I would try first.
    hope that is a help.
    Blitz
    Defender200Tdi Guest
    Saw this on autotrader.com.au if any of you series fellas are interested.
    <div class='quotetop'>QUOTE</div><div class='quotemain'>Holden motor, with conversion kit to suit series 1 to 3, $150 KOTARA SOUTH 02-4943 3552[/b][/quote]
    I've now idea where Kotara South is, obvisously NSW somewhere!
    Paul
    Jun 2003
    Ok, the engine mounts themselves are of a 'T' shape in section. One is bare metal (indicating that it is an aloy due to the lack or rust, and the other was once painted blue, but is a bit chipped now. THe engine itself is tilted up at the front by about 4 degrees max. I don't know about the rear mounts as I was in a suit, and the ground under Grover is red, dusty gravel.
    The rubber bases between the mounts and the chassis are 4 cm (1 1/2 inches) thick.
    I guess that I have a couple of options.
    Replace the rubbers with thinner ones.
    Replace the mounts with different ones.
    Get the chassis modified so that the attachment is lowwer ( I don't know if this has already been don, but i'm inclined to not play with the chassis if I can avoid it )
    1994 Discovery TDi
    Jun 2003
    Oh, I almost forgot.
    Cast into the engine end of the mounts is "CRS EM5"
    Don;t know if it has any significance, but it is upsidown as if the mount was up the wrong way.
    I have seen a 186 conversion in the flesh, and that was much lower and a bit further back.
    1994 Discovery TDi
