Thread: Stop light switch !!
    Upwey, VIC
    Does anyone know if the stop lamp switch on a non-ABS S1 Discovery is adjustable ? The haynes manual tells me no, but the LRO factory manual tells me, Yes !! The reason I ask is because I had to replace mine this morning, but when I installed it I thought that if u just touch the brake pedal the lamp switch should work, instead i have to press it in about 4-5mm before it works !!
    Bracken Ridge, Qld
    How can you tell the difference between 'just touching it' and 4mm of travel ?
    Do you have a micrometer built into your shoe ?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Upwey, VIC
    U know what i mean, ops: ....
    Jun 2003
    Launceston, Tasmania
    Sounds like it needs to be adjusted to come on earlier Matbor, shouldn't be too difficult, but then again, I don't know discos
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Rovernaut Guest
    Hi matbor, not sure but does the brake peddle have an eccentric pin and bush? If so you can then adjust the pedal height a little higher so it touches the switch pin.
    My cruise control switch didn't work after I re kitted the clutch master cyl' and I could not get the clearance right so I glued a spacer on to the activator pin and it now works great. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Any more airflow meters for sale I'm still after one.? [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Cheers mate,
    Rovernaut
    Upwey, VIC
    fixed it, just put a couple of washers behind it, works alot better now...
    Bracken Ridge, Qld
    The unenlightened see Land Rovers as anachronistic, as relics of the past.
    We know that they are cleverly designed to allow the expression of just such Aussie ingenuity !
    Thanks LR.
    gone
    1996 Discovery 1
    current
