Results 1 to 10 of 12
Thread: What battery should I connect compressor to?
    May 2013
    Perth, WA (Northern Suburbs)
    Hi guys,
    I have just installed a dual battery system in my Defender 110 with a USI 160 kit from Traxide.
    I have connected the winch to the cranking battery (as suggested).
    I have also fitted two external power outlets for my portable ARB air compressor to save stripping out the passenger seat etc every time I need air.
    The compressor draws 28 standard and 50 amp under load.
    Should I connect the power sockets for the air compressor direct to the cranking battery or should I / will they be ok connnected to the Aux battery?
    Ian
    Queensland
    Hi Ian and as it is always recommended to have your motor running while using an air compressor, particularly one that draws the current levels that yours does, then you can use the Anderson plugs connected to your auxiliary battery.
    Bacchus Marsh Vic.
    I've got my ARB air compressor wired direct to my 2nd battery.
    This way I don't have to have the motor running while I do the tyres.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    May 2013
    Thanks guys.
    This forum is awesome, it's like instant messenger
    Ian
    Alex Heads
    As Drivesafe said, you always want your engine running, compressors chew massive amounts of power. If you want to wire via a plug, Anderson's are definitely the go.
    I'd always go via the main battery, and ALWAYS have the motor running.
    You'll end up killing your deep cycle 2nd and/or flattening the crap out of it, if you use a 2nd without the motor running. Save it for for your fridge & toys.
    May 2013
    Thanks folks,
    I do intend to use the compressor only with the engine running.
    Ian
    Queensland
    Quote Originally Posted by Ian1878 View Post
    As such, you can connect to either battery.
    BTW, the main advantage of having your motor running while using a compressor is that because of the higher voltage at the compressor, the compressor runs faster, which in turn means you pump your tyres up quicker
    Jan 2014
    Berwick
    G'day all. As you usually inflate your tyres at the end of the fun stuff and your second battery is in good shape then pumping your tyres up usually doesn't do much to the battery.
    I have never run the car whilst inflating and they were serious sized tyres.
    I run an ARB compressor on an optima.
    With the ARB compressor it is usually finished before my mates. So good in fact I pick up my new one today for our 130 dual cab we just got on Monday.
    Running your deep cycle low is what they do.
    The compressor solid mounted is one of those well used gadgets. I've used it to help fix other travellers camping stoves an all.
    I had pressure switch problem once though. It must have had a break down inside. Stripped the pressure switch off. Sprayed it in side. Put it back on and away it went. I carry a spare now just incase. $9 from ARB.
    The information the spins around on this site is priceless. Great family.
    Aug 2008
    West Pennant Hills
    If you are drawing 50amps and connected to the auxiliary batter which has an voltage sensitive isolator, chances are the voltage drop will cause the isolator to cycle on and off. It will depend on the initial output and net available output from your alternator. I think its better to connect to the main battery. Engine running is a must to me.
    Bracken Ridge, Qld
    If you wireyour winch and compressor to the cranking battery, what wouldbe the POINT of the 2nd battery ?
    I would have thought the cranking be reserved for craniking and the AUX battery for - well, other stuff ! ???
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
