Results 1 to 10 of 11
Thread: re:Lower control arm bush install.
    Apr 2013
    qld
    Hi all, well i solved my bush issue with some measuring and a friend on a lathe we made a bush reciever not a spacer as i previously called it.(my mistake if any one went what the!) So bushes and lower ball joints fitted was able to use a press at work,, 4 wheel alinement done today . What a difference to drive now no knock and glides alongthe road.
    Jan 2014
    Chapel Hill, Brisbane, 4069
    Hello Howie
    I think I need to replace the bushes on the lower control arms of my D3, and have seen some poly aftermarket items. Wondering if you considered them? Pro's Con's? any info anywhere on changing the bushes? I searched the forum and (surprisingly) couldnt find much....
    rgds
    Victor
    Aug 2010
    I tried SuperPro nolathane anti roll bar bushes - in short don't bother.
    I'm getting the standard rubber bushes back in next service.
    The latter design OEM bushes are much better than the original designed ones.
    Cheaper to replace the whole arm rather than replace the bushes.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Kingston, Tassie, OZ.
    Quote Originally Posted by ~Rich~ View Post
    agree 100% , as the lower ball joints have a similar lifespan to the bushes, and labour etc adds up!
    jc
    Jan 2010
    Mont Albert, Victoria
    Regarding the front arms it seems there are a few versions available. What part number is recommended for a D4 3.0 with EAS? Thanks Andy.
    Jan 2010
    I believe these are the part numbers for a 2010 d4. Can anybody confirm please? All the web says d3, but I'm assuming they are the same for d4.
    I'm looking for a complete lower wishbone set (l and r) including bushes, ball joints and bolts.
    Thanks, Andy.
    D3's are different to D4's. There are also sublet changes to them also Eg: 11.5MY to say 13MY. The only way to get the correct ones for your vehicle is via your VIN.
    Jan 2010
    2010 D4 Lower control arms
    I have just had my 2010 D4 done.
    Part No.s are
    LR025613 Left
    LR025610 Right
    Until I ordered them via VIN I was thinking LR028245 and LR028249 but these are for D3 it seems.
    If you google the D3 ones you will find after market ones as well as OEM are available.
    I got OEM sent from Duckworths in UK. I had them installed by an independent, they sort of said they would put D3 ones on if they were supplying as they are much cheaper. The OEMs for D4 were talked about as being about $860 a side for just the part for the D4 here in Australia.
    Gerry
    Apr 2013
    qld
    Talking
    Hi , Dapper . I did consider poly but the feed back was they would make the ride harsh . So i went with OEM bushes and lower ball joints did the job myself , ihad acess to a press at work so it made the job alot easy for me. The hardest part was getting the bushes out drilling out the rubber and using a hacksaw through the outer sleve. The bushes and ball joints were a good fit back into original arms, they say they can stretch but were fine. I can not rember where i got the info to do the job pretty simple realy . Will have a look to see if i can find it mean while google it , it was on a uk landrover site i'am sure. A lot cheaper as well.
    Piper Guest
    Hi
    I just changed my control arms last weekend the job took about 4hrs each side cost $380 for each arm oem
    This was helpful DISCO3.CO.UK - View topic - How to fit new wishbone (lower arm) and track rod end
    Also I purchased a DVD of the D3 workshop manual off ebay for $10 between the two it was easy enough no special tools are required but you will need a torque wrench that goes up to 300nm.
