Results 1 to 6 of 6
Thread: Oil light gone.
    Jan 2010
    Oil light gone.
    Trying to sort out some electrical gremlins I was hunting for a 12v ignition feed. Whilst doing this of course, the oil pressure warning light was on, saying hello as it should. I'm not sure what happened but whilst rummaging through the spagetti loom behind the instrument panel there was a crackle and I saw the oil light go out.
    The bulb is fine, I no longer have power to the bulb on ignition.
    So what might I have blown up? All the other dash lights are working. Is it possible to melt the oil pressure sender with a short, or is there a fuse or diode somewhere that I need to check?
    youve probably just killed a connection or fractured a wire.
    pull the spade off of the sender, check that its still making to earth, if it is then leave the wire off with your meter plugged in and wiggle things around till it shows 12V.
    If that gives you nothing put it all back (assuming the sender still works)
    probe the back of the bulb for 12v+ with the ignition on and then probe the other side for earth.
    that will tell you which side of the bulb is at fault.
    Jan 2010
    Putting the oil pressure spade to ground lit up the warning light, so looks like I fried the sender!
    Not sure how that sender works but it would appear that a short to the sender, kills it.
    I will order up a VDO sender with pressure and switch output. Bout time I had a proper oil pressure guage.
    Do you know if oil pressure light is a roadworthy fail?
    2stroke Guest
    Wouldn't drive mine out the carport without a gauge. I changed to a VDO mechanical gauge for both the water temp and the oil pressure, tells a much nicer story.
    Quote Originally Posted by manic View Post
    its a simple spring activated switch, when the oil pressure is low the spring over comes the oil pressure and pushes a plate across the contacts.
    yes shunting more than about 2A through the oil pressure sender switch will kill it.
    yes, comes under the catagory of non functioning warning lights and gauges. but you'd be unlucky to get pulled for it.
    Jan 2010
    I ordered a replacement switch from a local supplier (PRC6387) in case they picked it up on roadworthy
    All good though. Got a first time pass!
    What a delightful contrast to the roadworthy I had to go through two years ago on import!
    Looks like:
    New Year = New Red Plates.
