Thread: '94 Disco - Expansion Tank Needed NOW!
    Mar 2009
    SEQ
    Exclamation '94 Disco - Expansion Tank Needed NOW!
    I doubt our Expansion Tank can be repaired (has a split below the fill line), and it's some sort of plastic, but I really need one and wondered if anyone within cooee of Ipswich (Leichhardt, Qld) could recommend a supplier or wreckers that might even deliver (can they be sourced second hand I wonder?) so we could possibly fit it PRIOR to December 24th?
    I'm presuming it's not too difficult to take one out and replace it? A few hoses etc and we should be ok?
    Feb 2011
    Denmark Western Australia
    Hi it's easy to change, I will guess yours was white... Only replace with a black one and are about $60.00 on eBay ..Gary
    Mar 2011
    South Aust
    some silicone and tech screws with cap unscrewed might get you to a supplied at a pinch.
    Jul 2010
    Tasmania
    Quote Originally Posted by Gary S11 View Post
    Hi mate. Think you got that backwards. The original is black and prone to splitting. The replacement ones are white.
    Feb 2011
    Quote Originally Posted by Ravvin71 View Post
    You right ...had a blonde moment . Reverse what I said originally :-)
    Aug 2012
    Logan,Queensland
    Hi Dragonfan,
    I've got 2 here, 1 new ,1 second hand, If you need it urgently.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Ah, depends on what you call white, there are clear see through ones being offered for sale via Ebay, they are about $45 and are cheap thin CRAP! We were offered some and sold a couple and had to replace them, one on the day of fitting as customer was filling it, coolant was coming out of the seam and one a week later. Not worth the agravation!!!!
    If you are stuck, try using that plastic petrol tank repair putty and drive with the pressure cap off, I managed to drive 150 kms like that until I could get a sparec one
