It is not usually a problem bleeding these. I would be looking for a mechanical problem, as the need to pump is not compressing air, but just getting more movement. If it is an early slave setup, there is an adjustment on the pushrod - see the factory manual. Later ones do not have this. Also check pedal and master cylinder pushrod adjustment.
But the most likely problem is the pins that transmit the torque from the slave cylinder bell crank to the release fork shaft. There are two of these, pinning the two shafts to the tube that joins them. My guess is that one of the pins is broken on one side or partly sheared resulting in lost motion. These pins are highly loaded and should be replaced with genuine parts or other hardened pins - mild steel bolts only last a few weeks!
