Results 1 to 10 of 11
Thread: Thomas winch - worth rebuilding
    May 2013
    WA, South East
    I've got a 8000kg electric Thomas winch just pulled off the front of my new 1996 130, that needs some attention, broken electrical connections, corrosion, general rebuild, clean up and stuff. My question is, basically is it worth doing the repairs and rebuild, or am I better off to scrap it and buy a new winch? Trying to take into considation the mounting and electrics to replace as well. Any ideas appreciated.
    Trundle
    Nov 2011
    Worth doing if you have the time, bloody good winch but if you don't have the time, I do. So if you decide to scrap it you can put it in my bin
    May 2013
    WA, South East
    Cheers Isuzuscott, if someone else is prepared to have it in their scrap bin, then I'm prepared to invest the time rebuilding (for the moment anyway)
    But I will keep your kind offer in the back of my mind as I swear and curse and bash knuckles.
    Dec 2011
    Hocking, Perth
    I've had a few of these winches, I believe to be the best on the market, I'd rebuild it if I was you, take the motor to a good auto sparkie, he will rebuild it, the gearbox will just need bearings and bushes, If you decide to bin it, I'll take it off you...Good Luck....Joe
    2stroke Guest
    I have one of these on my 130 as well. It will drag the 130 up a hill when beached on the chassis and rear diff with a single line pull, that's good enough for me. And I'd rather stall the winch than break it or the cable anyway. If I need more there's always the snatch block. All solid quality inside, made before the explosion of cheap asian stuff onto the market. Only modification is that mine uses a one piece solenoid pack which has worked a treat. There's a thread in the recovery section that tells you how to make it work.
    May 2013
    WA, South East
    Cheers for that 2stroke, I'll go a searching for that thread you mentioned and will head own to Supercheap for a fresh box of degreaser tomorrow and get started on the rebuild. Appreciate the advice.
    Trundle
    Bearman's Avatar
    Hay Point
    My guess is that apart from the electric motor there will probably be little that needs rebuilding - probably a couple of seals.
    Cheers......Brian
    1985 110 V8 County
    Queensland
    Quote Originally Posted by 2stroke View Post
    Which thread?
    I put "solenoid pack" in and 5 threads came up. I havnt the time to go through all of them. I have just bought a one piece pack off ebay, Trex or something and of the 4 terminals, none have markings as to what they are for
    2stroke Guest
    Quote Originally Posted by 123rover50 View Post
    Which thread?
    I assume that if yours is like mine it has only 2 terminals on the actual winch motor? Mine has Thomas on the comtroller and thomas on the paperwork but Ramsay on the badges on the winch. The thread I'm referring to is entitled "Old Ramsay Winch Overhaul" and is in the recovery section. Hope this helps.
    May 2013
    WA, South East
    I think this is the one mentioned.
    old ramsey winch overhaul
    Trundle
