Results 1 to 10 of 15
Thread: Quick question re my new 2003 130
    Palmerston NT
    Loving the 130... drove it from Newcastle to Adelaide and now going up the centre in horrible conditions.
    I'm currently in Coober Pedy and had a horrible day driving into a gale force furnace like headwind (got a light camper trailer on too).
    The vehicle has an aftermarket engine temp management thing installed which is great. However today it alarmed when it got to 90deg... I think it's set to cut off at 95. So instead of sitting on 100kmh I sat on 80kmh and this kept it around 85-88deg.
    The car is chipped, larger intercooler, egr removed and has a 3" free flow exhaust and seems to be able to do 100kmh effortlessly in these conditions..
    Just wondering what advice folks can give me regarding the temperature? Is the 95deg setting just a very safe setting and would it be ok to get hotter than this or do I just have to sit on 80kmh to keep it below 90deg do you reckon?
    Also the handbrake would burn my leg if I left it against it for more than a few seconds... as the heat from the transmission was pretty hot! Is this fairly normal? It was working pretty hard and a long day...
    Jan 2012
    Now in Sunny Perth
    Those temperatures seem pretty normal, I'm not sure what sort of sensor it is as it may be sensing block temperature rather than actual coolant temp, if its the same as mine you could add another 5degs ish for coolant temp. I hit temps very similiar when towing our camper trailer and like you reduce speed to lower temp slightly.
    My main concern when towing is transmission temperature. My car came from the UK so doesn't have the gearbox oil cooler but I'm in the process of fitting one. Its a thermostatic block on the side of the gearbox that opens at 74degs. On the defenders its a simply loop of pipe which IMO isn't good enough so I'm fitting one of these
    Transmission OIL Coolers Round Dual Pass Tube AND FIN Aluminium 12 Inch | eBay
    I also fitted one of these
    www.discovery2.co.uk - Transfer box Sump
    to see if that helps.
    Palmerston NT
    Thanks Ned.. the previous owner thinks it's the direct engine temp it's reporting... not the coolant... but he's not 100% sure... I guess the engine would get hotter than the coolant?
    Jan 2012
    Now in Sunny Perth
    It's a good idea to know block temperature tbh, the standard coolant gauge is slow to react and if you loose your coolant may not react at all. I drive by my engine guardian and pay little attention to the actual gauge.
    Jun 2007
    Margaret River
    Quote Originally Posted by djambalawa View Post
    The vehicle has an aftermarket engine temp management thing installed which is great. However today it alarmed when it got to 90deg... I think it's set to cut off at 95. So instead of sitting on 100kmh I sat on 80kmh and this kept it around 85-88deg....
    Are you using an Ultra Gauge or similar hooked to OBD2 socket?
    If so it will be reporting the cylinder head temp.
    My 2.2 130 usually runs in the low 90s
    Palmerston NT
    I don't know what it is sorry.. just bought it with it installed... I'll try and find out
    Dec 2009
    Williamstown, Barossa, SA
    Air on the side of caution.
    The way I look at this is that you are doing exactly right. The Td5 is a small engine in a big vehicle which is also pulling a trailer in some fairly extreme conditions. Add to this the larger exhaust, intercooler and chip and what seems an effortless 100kph would have been hard work before all the 'additions'.. My old 99 Td5 130 was working its nuts off at 110 without a trailer and I was always mindful of this. I'd continue as you are, enjoying the power when empty and in cooler conditions, but take it steady and keep your temp watchdog set at 95deg when out bush in the heat, thus giving the engine an easier time. As for the handbrake, yup that's normal... The passenger will be burning their leg on the small bit of seat base that's visible under their right leg too!
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Palmerston NT
    Thanks all... we'll we had a nice tail wind all morning and she just purred along at 100kmh with temp in the low 80s...
    Those transmission cooler adding look good will look into them
    Jul 2007
    Your temp setting on the alarm is conservative. Does the gauge look like either of these? If so then likely to be a temp sensor under a bolt on the head.
    Look at the temp gauge on the instrument cluster, if it is sitting in the middle of the range the temp is still ok.
    The exhaust heating up the floor or park brake can be reduced by wrapping exhaust wrap around the pipe.
    All images are linked to publicly available ebay adds.
    Quote Originally Posted by benji View Post
    Maybe we're expecting too much out of what really is a smallish motor allready pushing 2 tonnes. Just because it's a v8 doesn't mean it's powerfull.
    One answer REV IT BABY REV IT!!!
    Jan 2012
    Now in Sunny Perth
    Wrapping mine today, if I can get clips long enough
