Get a RAM Mount with a suction cup. Have one in my D2 mounted to the windscreen. Doesn't impede my view at all - although I am tall 6'2".
Used offroad and is great quality
 iPad mount for D4
 iPad mount for D4
		Hi all,
Can anyone recommend a good iPad mount for the front of a D4. Something that doesn't involve drilling holes and is easily removable when not required. If you have any pics that you can incl. brilliant.
 Wizard
						Wizard
						I just bought a second Ram mount for a friend after he saw mine.
I bought it here.
Photo in my car. If you have an iPad Air you will need a more expensive adjustable mount as this type is not available yet.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
		Thanks both, decision made and thanks for the link ordered one this morning
I know it's too late. I have a Ram mount that secures via a malleable rod using the bolt for the passenger seat. The tablet is therefore lower and obstructs none of the windscreen. Mentioned as another option.
If you intend a lot of corrugated roads a bushie mate of mine steered me to the ram mount with three suction cups. Takes up a bit of windscreen real estate but it has only fallen off once despite some pretty rough roads.
Did you use the "standard" length arm - 95mm - or did you have to get the 153mm version...?
I use a ram Mount as well but opted to remove the cover just ahead of the screen in the dash. Under this cover is a screw you can secure a ram Mount to I used an additional screw tapped into the plastic under the cover. This setup obscures the factory screen and is a little unsightly without the trim in place, but is reversible. I find this very secure and it does not obstruct my view. I havea 10 inch tablet mounted like this. I find yhe factory screen of little use as mine only tells me the radio station which only needs to be changed each time I service the car!
