Results 1 to 10 of 24
Thread: PUMA RATTLE
    Jul 2010
    Terrigal sometimes, but mostly everywhere else
    Question PUMA RATTLE
    Can anyone with a Puma engine tell me if their engine sounds like a chaff cutter at certain speeds?
    Honestly, its sounds like 50 pairs of false teeth going round in a washing machine.
    I even asked to the amusement of Coopers, if the tappets were adjustable. Their reply was a bewildered, no their hydraulic. You idiot, Stimpy!
    1991 2 door Disco (current)
    2012 Puma ute
    2007 D3
    1976 2 door RR
    1977 2 door RR
    1972 FORD XY 4X4
    + 70 other vehicles and trucks
    Jun 2008
    Drouin East, Vic
    Yep mine sounds like that. I believe it's something to do with the common-rail injection, I've never worried about it as from what I've read on here it's characteristic of the tdci engine.
    Mar 2010
    Gippsland
    Metal box of spanners
    Hi. Mine is the same - only when accelerating between 1500 and 2000 revs - it's standard I believe ? Tried to get it rectified with new eCU etc , but no change. Had it for about 60000 KMs now ( now 110000kms ) car runs great though. So I'm just putting up with it and adding it to the list of LR idiosyncrasies . If you do decide to " fix it " and are successful , let me know !
    Ocean Reef WA
    Mine does it and it is apparently the injectors. I've got a remap and it's made very little difference.
    At times the engine runs so sweet and then will rattle horribly for a while then off it goes again. Some say Transits do it as well but I've never heard one as noisy as this.
    I've also found it helps if I don't wear my hearing aids........
    AlanH.
    Feb 2009
    Hi All mine's the same. i got a replacement ecu and rattily noise still there
    and between 1500 to 2000 rpm.
    Reading about defender diesel's it's a quite one.
    n plus one Guest
    Same same.
    Aug 2011
    Buffalo, Vic
    Mine had the same problem, turns out it was dirty fuel (moisture) and and then the car needed the injectors re-programmed... all sweet now.
    Mar 2010
    Gippsland
    Who did you use for the re programme
    Quote Originally Posted by Goulies View Post
    Can you share with us who fixed your rattle. Maybe they have the right process to fix what some of haven't been able to do ? Any info would be appreciated.
    Feb 2009
    Good call Danske, it would be good for any info would be appreciated . I thought a new ecu would be a reprogram. not that i would know, i just thought that ecu was the brain..
    I'm sure someone will correct me ... if it not .... thanks
    Central Coast NSW
    Just got the new Holden Colorado for work, it's engine noise is worse than my SVX.....seriously
