Thread: I think it's the starter motor?
    May 2010
    Gisborne
    Question I think it's the starter motor?
    Hi all
    Recently, and only occassionally on start up, when I turn the key there is a slight delay then the car fires up. The longest would be a 1.5 second delay. Most of the time it's fine.
    Any thoughts?
    I'm thinking it could be the starter.
    All battery leads/connections are fine.
    Mick
    JDNSW's Avatar
    Which model? If it is the Isuzu, I would suspect the engine/chassis link under the alternator, or the starter solenoid. Can't comment on the other engines, but wouold expect something similar.
    May 2010
    Gisborne
    Sorry.
    It's a td5.
    I recently replaced the rocker cover gasket and there is a bit of old oil around the starter motor.
    Perhaps it needs a good clean up around the connections.
    I'll go there first.
    Don't ignore it, the intermittent nature gets worse.
    Then one day, it won't fire at all. In a motel forecourt. Ask me how I know.
    But switch off & on again, it's fine.
    I didn't trust it after that & changed it.
    Max P
    Mandurah WA
    Could be diesel contamination from a leaking fuel regulator, which sits just above the starter motor, or the contacts in the solenoid need replacing.
    SW of Geelong
    Quote Originally Posted by noogie View Post
    Sorry.
    ...............It's a td5............
    Most likely to be the contacts in the starter solinoid, very common problem with the Td5
    See here for how to fix it...... Td5 starter repair
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    May 2010
    Gisborne
    Thanks all. I might get mechanic to look at that.
    He said pretty much the same things.
    Mick
