There are probably other glues made specifically for rubber, but I use a contact adhesive, for example, Kwik Grip from Bunnings, to stick rubber buffers to powder coat. It's normally applied to both surfaces then pressed together after it dries. Where you've got to slide something on it can be applied wet, but you'll have to hold it in place until it dries.
Silicone wont stick to rubber very well at all.
Cheers, Murray
