depends on what gear you have to do it with.
you can change a series clutch without removing the engine or the gearbox, you can just seperate them and support the gearbox from under the bell housing and a beam through the doors with arope through the access panel under the center seat... (still have to drop the rear prop and uncouple the front at the slip joint tho)
