Results 1 to 10 of 12
Thread: Rover 3 Litre P5 Mk1
    nesjules Guest
    Hi Guys
    To keep my 2010 Puma Defender company I've acquired a 1961 Rover P5 3 litre. It's in good old condition with all the original papers etc.
    My problem is I need a new brake master cylinder. It keeps sticking when the pedal is fully depressed, and doesn't return. All the seals were recently replaced and all looks OK when stripped but it still sticks.
    Does anyone know where I might get one in Aus, preferably Melbourne?
    Or alternatively a UK supplier.
    Jules
    St Helena,Melbourne
    4.28 MB
    You could get it re-sleeved in s/steel if its beyond a seal kit , otherwise one of the british car mobs should be able get one for you.
    Try automotive surplus in Mitcham.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Western Victoria
    If you are after parts, another supplier is Graeme at British Car Components in North Melbourne
    May 2008
    Bundaberg Qld
    Any Rover car club should be able to help you or steer you in the right direction
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    sometimes it is not the master cyl but the rubber hose(s) collapsing
    do all the wheel cyls bleed with a good flow of fluid?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    nesjules Guest
    Thanks for your help guys.
    The main problem is that if I try to bleed with the engine not running, there appears to be nothing making the master cylinder piston return (despite the presence of the return spring).
    As soon as I start the engine and the servo kicks in it works OK - most of the time.
    The piston appears to be sticky, but seems OK stripped out on the bench.
    I'll try the mob in North Melbourne.
    Cheers Jules
    East-South-East Girt-By-Sea
    1.20 MB
    I've got an engine out of a P5 Mk1 sitting in the shed.
    Looking for a P5 Mk3 suffix "C" engine or even just the crank and con rods.
    Jan 2013
    Central Australia
    I love the P5s, well done and good luck
    Brisbane, Inner East.
    Diana, slot in a Chrysler Hemi 265. Give it some horsepower and performance.
    URSUSMAJOR
    1.20 MB
    Quote Originally Posted by Brian Hjelm View Post
    Why?
    Its not the purpose of the exercise, if I want performance I have both the 4.6 RRc and the SDV6 D4, I want the bits for a Series LR.
