disc rotors? If so none, use anti seize on the grub screw and the back of the rotors. The rotors won't come off once the wheels on.
Disregard the above ^^^^^^
Hi I am up to putting my new rotors on my disco tdi 300 and not sure what strength Loctite to use. I have Loctite 243 but not sure if that will be ok , or do I need Loctite 272 or any other suggestions![]()
Its a disco 1 had thread lock on bolts, rave says Loctite 270 but its not made any more.
Loctite 270 is high strength. 2701 seems to be a close replacement. Probably any medium to high strength threadlock would do the job.
