Results 1 to 2 of 2
Thread: Rear chassis cross member repainting
    Aug 2009
    werri beach NSW
    What type of paint would you use to pretty up the rear chassis cross member, the bit you see from the back. My Puma is only 4 years old and the coating is all most see thru and surfaces starting to rust.
    Jan 2008
    Goonellabah N.S.W.
    Hi, my Puma is 2010 model and the cross member paint had started to deteriorate. I masked it up and sprayed it with Tectyl. It remained sticky for about a week but now has ahard matt surface which suits the crossmember plus will stop any rusting.
    Jim
