Results 1 to 10 of 13
Thread: what is this, nissan
    Sep 2010
    adelaide
    nissan 2 stroke 3 cylinder diesel, last run in the early 90s. installed in the 70s.
    numbers on the block are K 2 0730 3 D 2236
    May 2009
    West Gippsland - Victoria
    Possibly a Yanmar in disguise ?
    Deano
    Davehoos Guest
    worked on an old shibura lawn mower that looked similar-it had a injector pump as part of the block but otherwise is similar.
    Mandurah WA
    Drilling mob I was with in the early 70's had UD -Nissan 4WD truck with the 3cyl 2 stroke diesel......sounded great!
    Moruya Heads/Sth. Coast, NSW
    GM-Detroit Diesel had a 3 cyl. 2 stroke diesel, known as the 3-71, Regards Frank.
    Brisbane, Inner East.
    Quote Originally Posted by Tank View Post
    not to forget the 3-53.
    URSUSMAJOR
    Quote Originally Posted by Brian Hjelm View Post
    It's not a Detroit
    Sep 2010
    adelaide
    Quote Originally Posted by eddy View Post
    that’s the one, but i can not locate any info, looks like i may have inherited 3 of them
    Back down the hill.
    I'm too tired to look for you , but ferret round here HCVC Vintage Truck Forum - Index there's at least one thread about them. Heaps of knowledge and interest that you will probably enjoy too Frank.
    Quote Originally Posted by Naviguesser View Post
    It's not a Detroit
    Are you referring to a 3-53? If so, it most certainly is a Detroit diesel. DD's came in cylinder capacities of 53, 71, 92, 110, 149 cubic inches. Then there are the monsters made by GM's EMD operation used in locomotives, power stations, ships, etc.
    Nissan had a V5 version of their two stroke diesel in trucks in the 1970's. It had an interesting exhaust note
    URSUSMAJOR
