Thread: Clean MAP, amazing difference
    Dan Guest
    My Deefa seemed a bit down on power towards the end of a trip up north recently. Reading the AULRO site, I came across a post by a member explaining how to clean the MAP unit in a TD5 Deefa (thanks Josh).
    http://www.aulro.com/afvb/1669310-post2.html
    Did mine today and it made an incredible difference. Much, much better pulling power. http://www.aulro.com/afvb/images/smilies/smile.gif
    If you own a TD5 and haven't cleaned the MAP sensor, I can't recommend it highly enough. Only took ten minutes and a can of electrical cleaner.
    It'll be part of my regular 20,000km service schedule from now on.
    Jul 2009
    Lake Macquarie NSW
    Hey Dan good to hear.
    Have you got rid of the EGR? A whole lot of benefits there.
    Robbo
    Dan Guest
    Yes, Robbo, I took it off when I had the ECU chipped and did a couple of other mods. Big improvement overall but power was definitely down recently and the clean MAP sensor has made it better than ever. The TD5 motor seems to have a lot of potential.
    May 2010
    Gisborne
    Wack an allisport intercooler and 3' exhaust and watch it go.
    Recently put an allisport performance intercooler in and boy what a difference that makes.
    I'm going to clean that map sensor out.
    Thanks for the link.
    Dan Guest
    I bought a second hand inter from the later model Deefa as it's a bit bigger and certainly made a big difference on a budget. Yes, a wider diameter exhaust pipe would be nice. Just wish my old one would wear out so I can justify replacing it!
