Thread: Uniden UHF - no transmit
    Geelong, VIC
    My trusty old Uniden UHF decided it didn't want to transmit on my last outing.
    Still receives fine, but definitely not worthwhile repairing (think I paid $50 from a member on here about 7 years ago).
    Is there anything agricultural I can check before I bin it?
    Its got a 4-pin microphone socket if that makes any difference.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Hay Point
    I have found that the push button on the handpiece is usually what gives up the ghost Steve. Sometimes it can be fixed by activating ( pushing) the button a number of times which gets the contacts working again, but mostly it's a replacement handpiece which makes it economically cheaper to buy a new set.
    Cheers......Brian
    1985 110 V8 County
    Geelong, VIC
    Thanks Brian - I'll check out the button switch first...
    Steve
    Geelong, VIC
    Oh well - checked the switch and its working fine. Looks like time for a new radio
    Steve
    Oct 2011
    Mornington Peninsula
    Hi Steve,
    Have you checked the aerial and lead.? UHFs can recieve a signal with a lousy cable/aerial however will not transmit. Check to ensure the cable/lead is securely attached at the base of the aerial.
    Worth a look before expending $$s
    Rgds,
    Rob
