Greetings all,
I had my fridge running in the Defender (MY13 2.2) and this morning I tried to start the vehicle and the battery was too flat to engage the starter solinoid,
I have charged the batery and the engine now starts...but the engine check light is ON, I assume that the ECU has recorded a low battery voltage fault?
How does one read the code?
How does one reset/clear the code?
Or is a low battery code what we used to call a "soft" fault that will go away if the ECU does not read the same error after X number of starts?
