Results 1 to 10 of 14
Thread: Recommendations for Windows on new MacBook Pro please
    May 2012
    Darwin
    Hi guys,
    I'm getting a MacBook Pro for study, this means I am upgrading my 2007 vintage Toshiba.
    I want to also use the Mac for my Hema and oziexplorer.
    What would everyone/anyone recommend to use. I have tried to search but can't seem to find exactly what I need, so if you can direct me to an applicable thread I thank you in advance.
    Cheers, Adam.
    Barmera .SA.
    Google is your friend.
    Type this Windows on Macbook Pro into Google, I got almost 90 million answers in less than 1 second, including many links to Apple itself.
    Better yet, sell that shiny over priced bit of junk from Apple and get a cheaper better real Windows laptop from Toshiba or similar.
    Feb 2010
    sydney
    You can partition the hard drive.
    Doing this means that you will have a portion (you choose the size) of the hard drive set aside to solely to run windows on. This method is not using a "windows for Mac" program, but instead is using the same windows program you would install on a PC.
    I like this method because it keeps everything separate and just works.
    I did it recently and was helped every step of the way by apple tech support on the phone.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    i personaly use vmware fusion and install windows into it.
    i don't worry with boot camp.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jul 2007
    North East Victoria
    Quote Originally Posted by incisor View Post
    I'm using vmware fusion too. works well.
    Don't use parallels. its crap.
    Pete.
    Oct 2011
    Hunter Valley
    X2
    Although I was only using it for E-Tax and that is now available for MAC as well.
    Ron
    May 2012
    Darwin
    Thank you for your experience. I will check out VMware fusion.
    Do any of you use OziExplorer on VMware without Windows?
    I found out today with my own research I will likely also have to use windows to support OziExplorer. Just more.... $$$
    Oct 2011
    Hunter Valley
    When you use VMware fusion you need to install windows as a virtual machine under VMware, ie you still need a copy of windows to run OziExplorer.
    Ron
    May 2012
    Darwin
    Thanks for that info Ron. I would like to not have to buy windows. I am a cheapskate.
    Oct 2011
    Hunter Valley
    Don't you have a copy of Windows already on the laptop you are about to decommission? Any chance of re-using that version?
    Ron
