Results 1 to 10 of 11
Thread: Identifying lift height above standard
    Oct 2013
    Moruya N.S.W
    So I have a 1985 V8 Land rover county 110, It Came running 33 inch tyres and they only seem to rub in extreme conditions/angles but more on the suspension components not necessarily on the gaurds.
    I'm looking at buying some braided brake lines to improve the braking and need to know what length I need to order.
    Can someone suggest what lift I might have. and is there any potential problems with going a little longer with the break lines.
    Dean
    Geelong, VIC
    If its not standard height it will likely be 40-50mm raised. Measure the front bump stop clearance - I think standard is about 65mm.
    Buy the lines for a 2" lift. I've run them at standard height with no dramas and you'll know they're long enough if you do have a slight lift.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Perth WA
    Hi Dean,
    Nice choice of vehicle there.
    On my '85 V8 County, I went for +2 inch braided lines. I run Gwyn Lewis dislocating suspension, and the brake lines are all good.
    Andre
    Oct 2013
    Moruya N.S.W
    Thanks Guys, 2" longer hoses it is.
    May 2006
    Woolgoolga
    Personally I'd go 100mm longer.
    Oct 2013
    Moruya N.S.W
    Too late ordered 2 inch longer ones, should be enough. And I'm hopeing that combined with new discs, pads and less lubrication from the no longer leaking swivel hubs I should be able to get the old girl to stop
    Perth WA
    Quote Originally Posted by Deanslost View Post
    When I did all this, I also bought new pistons and seals for the front calipers. It wasn't too expensive, and they were definitely in need of a rebuild at this age.
    Andre
    Oct 2013
    Moruya N.S.W
    Good thinking, will look into a rebuild kit
    Geelong, VIC
    If you want it to consistently stop well, rear discs and a D1 booster are an upgrade that will make you smile.
    Steve
    Oct 2013
    Moruya N.S.W
    Does the rear disc upgrade require new rear lines aswell ?
    Will have to look into the cost of the parts. As all things land rover need to be approved by the minister of war and finance
