Results 1 to 10 of 22
Thread: Old Man Emu suspension kit
    Jun 2008
    Drouin East, Vic
    I'm planning on fitting new springs and shocks to the 130 as the rear end is quite sagged and the original shocks are pretty tired, planning on lifting maybe 40-50mm above standard height to improve tyre clearance and ramp-over angle also. Have already fitted a Tom Woods double-cardan front shaft in preparation for this.
    Was looking up Bilstein and Koni part numbers and prices today, and came across some old threads on Aulro that recommended Old Man Emu as a better option. I've requested a quote from OME for the heavy-duty kit they sell for the 130. Wondering if anyone has any experience with this setup, good or bad? Will be comparing against either Bilstein or Koni Raid shocks, plus springs from LRA. The OME kit includes springs and shocks, plus caster correction bushes which I won't be using.
    South Yundreup,WA.
    OME are crap for Defenders and have a rep of breaking mounting rings, I would go Koni or Billies. I have had all 3 on various vehicles.
    I looked at the OME kit and it was ridiculously priced.
    I went Billies on my Defender with King Springs. I bought the Billies from Shock warehouse in the US and 1/2 price to buying here inc US air freight and were at my door in 4 days. King springs I got from Coventry's (ask for trade price).
    By doing this I purchased the shocks, springs and polyairs for around the same price as just buying the shocks in Australia, King Springs and Polyairs bought in Australia.
    Then if you want them fitted you can double the price.
    I had Koni adjustables on my old RR and they are the best but a lot more expensive and then there are the ultimate Koni Raids.
    Not hard to fit.
    CraigE
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Central Coast NSW
    Just fitted a set of Raids on the rear, replacing TerraFirma Expeditions. The differece is substantial.
    As once (or twice) said you get what you pay for.
    Mar 2010
    Mudgee-ish
    What I found when I went suspension shopping was that OME cater for touring with the kitchen sink crowd, i.e. they only do firm. Also, I wasn't after a lift, just comfort. I ended up with Dobinsons (springs and shocks) with a mild 25mm lift. They have spring rates to suit whatever you are after. Shop around and you will get what you want at probably a better price and/or quality.
    Quote Originally Posted by CraigE View Post
    Not hard to fit.
    CraigE
    Sorry totally disagree and have had OME's on three 90's I have had
    One was a winch challenge trucks and they took a beating with no problems
    And still have them on my 90 which has been 45,000ks around Australia on all the worst tracks with out a problem
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    This might be worth a read regarding springs and rates:
    Understanding Spring Rates
    As far as shocks go, Koni raids are going to be about the best bolt on shock, but wont allow for much extra travel over stock.
    Jun 2010
    I agree with Reads90.
    Had OME shocks on my 110 which was a tourer...no kitchen sink but went more places than most in some of the remotest and harshest conditions including cross desert.
    The shocks took an absolute hammer. So much so that the paint turned from yellow to burnt black and the shocks still worked perfectly. Pretty sure I posted pics in my 110 build thread.
    No broken mount rings either and they did over 50,000kms. Changed them just to be on the safe side before going on another trip for a new set of OME's and used the old ones as spares. Another 25,000kms and still no broken mount rings.
    That the shocks still worked perfectly after getting that hot was a pretty good recommendation for me.
    Goolwa SA - but top ender forever
    I bought my 94 disco in 95 put OME under it straight off - they have worked perfectly and I have clocked up 300 000km on her.
    It is just starting to sag on one side - far as I'm concerned i could not have asked for more than that
    Jun 2008
    Drouin East, Vic
    Got a reply to my price enquiry on the OME suspension kit, $1968.00, back to plan A at this stage which is Koni Raids, and springs from LRA. LRA are happy to trial-and-error the springs until they're 'just right', and the Konis can be adjusted, so should be difficult to go wrong that way.
    Oct 2010
    Adelaide Hills
    Quote Originally Posted by POD View Post
    Exactly what I did after trying a few other options that either broke or were too harsh.
    I went with orange/yellow 270lb rears and pink 180lb fronts. Has close to standard ride height with bb winch and dual rear wheel carrier. If I was super fussy I'd get LRA to order a custom 240lb rear set to get the ride spot on. Run airbags in the rear but havent needed them.
    Havent been on a trip with the Raids yet, but on-road they've made a substantial difference so looking forward to trying them out on some corrugations.
