Results 1 to 8 of 8
Thread: oil filter
    May 2006
    Ulverstone,TAS
    oil filter
    Have tried to get oil filter top off,but it seems to be really tight.
    Is it left hand thread to undo or right hand thread before I break it..
    Doesnt look as if its had a service for a while.
    Air/fuel/pollen filter and charcoal breather pretty mucky...
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Avoca Beach
    If it's like every BMW 6 petrol engine, it has a bolt in the middle which is just a normal righty tighty.
    Regards Philip A
    Manly QLD
    big plastic cap, 36mm socket, right hand thread and should not be really tight, book spec is 25nm - it has a rubber O-ring.
    Apr 2007
    South Australia
    I sheared the plastic nut of the top of mne the first time I tried to change the filter.
    Ordered a new one and waited, and ended up using a piece of rubber mesh over the whole thing and then an oil filter wrench over that and lots of swearing and cracked plastic but off it came.
    I have only ever done it up hand tight since, again with a rubber mesh for a bit of extra grip.
    Just that rubber mesh stuff you use to stop things slipping around on the dash or for place mats etc.
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    Jan 2011
    JSP,
    Where did you find the new top? Mine split like two pins at the end of a lane.. :/
    Regards,
    Aug 2010
    Sunbury, VIC
    They are available second hand on ebay, but they are all OS. I would call the BMW dealers and ask them, I'm sure it would be a commonly kept part.
    Apr 2007
    South Australia
    I think I got mine from island 4x4 in a box of bits I ordered to replace when I first bought the car.
    Oil Filter Top Cover LPX000070 Island 4x4 - Specialists in Land Rover and Range Rover Parts and accessories for all models. UK and worldwide mail order.
    South Australia.
    Feb 2014
    I know this is digging up an oldie, but I bought a new one from ritter land rover, was delivered to me for a very very reasonable price...as I always do, check the dealers first for parts, not always expensive
