Hi Dawsey, can you explain in a little more detail what was wrong with the mini jump start?
 Master
						Master
						Being this is my first vehicle that has a mind of its own (computer and such). Does hooking up a maintenance trickle charger straight to the battery cause any major concerns..And 1 more while I'm at it does jump starting another vehicle straight from the defender battery ok, we had a crap load of problems after doing this to my sister in laws new mini..don't wanna go through that. thanks
 Master
						Master
						Hi, she jumped a fella in a older holden straight from the battery. her mini at the time 1 month old last year, drove home and in the morning turned the key and nothing..no ignition lights just dead .dealer said this is a not to do.. computer error. $550 fix not covered by warrant apparently. what the error was I don't know, interested myself what the problem was I will talk to my brother and find out what happened
I've jump started a few vehicles from my puma and have had no dramas. I've also had the battery disconnected a few times and have just reconnected it and not had any problems.
Hi again Dawsey, can you ask if the motor was running ALL THE TIME in the mini during the jump start?
