Do you have a pic of the item
 Master
						Supporter
						Master
						Supporter Help - What's this
 Help - What's this
		I recently purchased a 1989 Perentie FFR (Hard Top). This was in the back. From what I can see it's metal (poss aluminium), about 2 inches diametre and 'bendy' (sorry for the technical description.
Does anyone know what it is?
G'Day Paul, welcome to the Perentie club.
If it is a 3metre spiral wound metal pipe, 60(ish)mm in dia, then it is an exhaust pipe extension allowing the vehicle to run and re-charge batteries without the operators dying of CO inhalation.
You can also direct the end into a small hole, this does an effective job of muffling the noise.
Looks something like this?
Cheers, BDave.
Replace "You are...!", with "Are you...?"
Army Land Rover Buyers Guide.
buymilitaryvehicles.com
Reunited with RFSV 51 680, 'Sleazy'!!
'00 VeryDisco TD5 Auto,
Nanocom Evo for D2 TD5 and Puma
Gone:RFSV, 51-699, Carryall 48-358.
 Master
						Supporter
						Master
						Supporter| Search AULRO.com ONLY! | Search All the Web! |
