Results 1 to 4 of 4
Thread: A/C rad
    Apr 2012
    A/C rad
    hello all, anyone had a leak on their A/C condenser radiator? I might be wrong but after changing the coolant last week I have a damp patch on the condenser radiator, I'm hoping its just coolant that has splashed on it, because it was green in colour same as the coolant I put in the cooling system. Also the A/C seems to be working ok , blowing cold, surely if the A/C had a leak all the gass would just escape, and there would be no cold air? Cheers ted
    Brisbane,some of the time.
    A refrigerant leak will be oily,not green.
    Keep using it you should be OK.
    Jun 2008
    Drouin East, Vic
    Stone damage to the condenser is not unheard of. They use a green dye in a/c refrigerant to show up leaks. I would clean it up and keep an eye on it. A tiny leak can take a while to lose enough refrigerant for the a/c to stop working.
    Quote Originally Posted by POD View Post
    Correct,forgot about that dye that is sometimes used.
    But a leak on a condenser will always be oily as well.
    Stone damage is easy to see,a little water mixed with detergent will soon show up a leak,particularly while the compresser is operating.
    But if the system is not working at all,don't use the detergent as the system may be in a vacuum,test the system pressure first.
