Marks 4WD Adapters do an adapter for the TH400 to the LT230 but that is one of the only commercially available ones. TH400 to Rover LT230 transfer case - Land Rover - Transfer Case Adaptors
Before you go down that path, you would also want to:The LT230 will be about 120mm longer than a standard series transmission and that has problems for the cross member behind the gearbox.
- Fit a Salisbury rear axle assembly.
- Fit disk brakes.
- Fit a CV front axle assembly (stage 1 swivels).
There were adapters for Ford C4 autos behind Ford V8 on series transfer boxes and these were done privately on a semi-commercial basis.
In spite of the space problems, you have more ratio flexibility using the LT230 transfer box.
On the disk brakes cookey on this forum is tooling up for disk brake conversions on Series 3 hubs, it uses bolt on components and the standard wheels (unlike other DB conversions which require aftermarket wheels). You will be able to retrofit SIII hubs to your SIIa stubs.
